THE LONG BOYS CLUB
by Ram4ever
Just DREAMIN right now
12:01 AM
11:31 PM
11:29 PM
11:24 PM
Meet big Bertha!
11:17 PM
Whats under the visor ?
11:12 PM
10:31 PM
Mounting a Sun Visor
10:16 PM
We got another van!
09:40 PM
#200080 - April 24th 2008 10:22 am Clean Electronic Ignition Swap
#200088 - April 24th 2008 10:41 am Re: Clean Electronic Ignition Swap [Re: NateNCBV]
rust_collector Offline
Loc: Horten, Norway
Looks neat!
#200099 - April 24th 2008 11:39 am Re: Clean Electronic Ignition Swap [Re: rust_collector]
I'm gonna try on my '67 whenever I get started on it.
GM ignition stuff is pretty reliable.
#200107 - April 24th 2008 12:09 pm Re: Clean Electronic Ignition Swap [Re: NateNCBV]
And you can buy it at 7-11! lol
#200161 - April 24th 2008 3:06 pm Re: Clean Electronic Ignition Swap [Re: Superbeast]
Along with a Big Gulp!
#216702 - July 12th 2008 10:40 am Re: Clean Electronic Ignition Swap [Re: NateNCBV]
Loc: Horten, Norway
Hmmm, the link seems to have expired...
Do you remember who made it?
Not that I care, as it won't fit my engine anyway...
#216707 - July 12th 2008 11:10 am Re: Clean Electronic Ignition Swap [Re: rust_collector]
If it is a D.U.I system, they make models to fit most every engine out there, Fords, Mopars, Toyotas, Mazdas, even air-cooled VWs! All based on a GM HEI system...here is their link, not sure it is who NATE was referring to, but...
http://www.performancedistributors.com/index.html
#216711 - July 12th 2008 11:29 am Re: Clean Electronic Ignition Swap [Re: Uncle_Fester]
Loc: Horten, Norway
IIrc, it was pretty much the same thing, just that it used an ordinary mopar distributor, with a heatsink and hei module bolted to it.
#217390 - July 14th 2008 7:06 am Re: Clean Electronic Ignition Swap [Re: rust_collector]
Here's another Mopar kit they offer. Pricey.
http://www.performancedistributors.com/dodgetripower.htm
#218918 - July 25th 2008 12:24 pm Re: Clean Electronic Ignition Swap [Re: NateNCBV]
Why spend all that money when you can do the same with junkyard parts?
I worked with a guy to try this out on an old Valiant I owned and it works great. Grab a junkyard electronic ignition distributor, grab an HEI unit from a junked GM product (get a four pin, the seven pin is for fuel injection), and wire it up according to this diagram. The HEI unit MUST be grounded on the backside, otherwise this is a fairly brainless and straightforward swap.
If you have the original distributor for your motor, I would recommend swapping the wieghts, springs, and vacuum advance pod from your original points distributor to the EI distributor to keep the advance curve correct. Otherwise you might end up with an incorrect advance curve in the EI distributor.
1 registered (Benoit), 2 Guests and 66 Spiders online.
ShortChevy, lilsparklez, Nerolus, vamxr636, waynerayder
6691 Registered Users
Wizard78 370
frscke1 331
HighwayStar 308
Uncle_Fester 250
lukester 203
NateNCBV 197
newkirkinc1 155
6693 Members
26218 Topics
