New from SoCal
by radicalran
36 minutes 14 seconds ago
Roof Upholstery...
by maples01
41 minutes 10 seconds ago
Today at 02:06 AM
just bough this baby...
by zombie72
Today at 01:30 AM
Today at 12:51 AM
Today at 12:38 AM
Yesterday at 11:20 PM
Yesterday at 09:37 PM
Yesterday at 08:53 PM
Yesterday at 05:29 PM
#218029 - July 22nd 2008 12:32 am need to do timing chain
zfreak Offline
Loc: Madison, Wisconsin
hi guys i have to do a timing chain on an 86 e-150 302 (efi i think) would someone beable to run me thru a quick how to idk how to do it but im going to try myself, what do you think the degree of difficulty is, thanks z
86 E-150 302FI
#218129 - July 22nd 2008 2:04 pm Re: need to do timing chain [Re: zfreak]
Big_Jim Offline
Loc: Memphis, Tn.
Well I put a timing chain in my 76 ford not too long ago with a 351w. I took out the radiator after draining the system. Then remove the fan, belts, waterpump, upper and lower pulleys and harmonic balancer. Be sure to line up the number 1 piston to tdc, it makes it easier later.take the first 4 bolts from front of oil pan to help remove timing cover. this will give you access to the timing chain
I would get the complete timing set and put the new gears in also. A double row chain set is better and lasts longer in my opinion. Remove the old chain and gears and be sure to line up the dots on the new gears to insure a proper installation. A word of advice, before installing the new crank gear, place it in a pot of water and boil it for say 10 minutes. This expands the steel and it should slide right into place. Then align the dots on cam gear to the one on crank gear and replace the chain. Replace the parts that came off. I always clean and paint anything that needs it at this time. Just take your time, go slow and you should be fine...Good luck...Jim
Edited by Big_Jim (July 23rd 2008 7:37 pm)
Proud owner of a 1976 Ford E-150 Shorty
"Now...give me that horizon!!"
#218324 - July 23rd 2008 8:24 am Re: need to do timing chain [Re: Big_Jim]
Ecovanner1963 Offline
Loc: Ohio
Yep, Jim said it all, you could however use a small torch (little $10 Cylinder type) to lightly heat the Crank Gear as well, I don't know about you guys, but my wife would BEAT SOME ASS if I was boiling a car part INSIDE out of a pot we eat out of. Jims idea is just as good though!!
If it didn't kill you, it only made you stronger.
#218333 - July 23rd 2008 9:40 am Re: need to do timing chain [Re: Ecovanner1963]
Ecovanner, I personally have a set of pots and cooky sheets I bought from the Salvation Army to use just for auto parts, like heating a gear so it goes on easier, or boiling a thermostat to test its operation (use a cooking therm to check the temp where the therm opens) All kinds of stuff like that.
You might also want to add one more post Ecovanner, kinda scarey there with the 666 buddy! lol
#218393 - July 23rd 2008 12:25 pm Re: need to do timing chain [Re: Uncle_Fester]
If the van has A/C "DO NOT" remove the lines to make room to work. This is a pressurized system and could cause major injuries.
#218416 - July 23rd 2008 1:38 pm Re: need to do timing chain [Re: Superbeast]
Loc: Ohio
Good call Uncle Fester, I didn't notice that.......and...done!
Moderator:  Uncle_Fester
0 registered (), 1 Guest and 74 Spiders online.
Metal_Skoan, SaabGuy
Uncle_Fester 318
Wizard78 311
HighwayStar 250
frscke1 200
Lee7673 144
al55 125
newkirkinc1 123
Ripper 122
keystonekid1978 114
6621 Registered Users
