#505115 - October 18th 2011 12:06 pm
GM Goodwrench 350 - best carb for this engine?
Loc: Russia
Hi! I have Chevy Van Beauville G30 1979, it was imported to Russia (yeah, I'm from Russia) in 2003. Shure, russian servicemans a little bit nasty, and after I got this van, I'm going to carefuly restore it. So, my new friend: At first, I want to replace old carb Rochester, but not sure what carburetor and intake I need for GM Goodwrench exactly - I think it's not stock engine or I'm not right? I hope, somebudy can help me in this case. Unfortunately, my english is not good now, and here in Russia I'm away from good information about American cars, so please excuise if I'm so stupid in this matter. Anton.
#505159 - October 18th 2011 1:15 pm
Re: GM Goodwrench 350 - best carb for this engine?
[Re: wbud]
 aboard
#505172 - October 18th 2011 2:03 pm
[Re: wbud]
Loc: South Dakota
Go with an Edelbrock performer intake and a 450 or 500 cfm carb on top. This is a very simple and maintenance free sertup.
Jeremy is my name, but most people refer to me as ASSHOLE!! ***UPDATED 12/14/11*** Shit for sale - 1987 Ford Econoline 300 six 4spd on the floor - $1,200 Impco CA100 Propane Carb (direct bolt to the slant 6 manifold) $100 1986 Extended Cab Mazda Truck - Runs, drives, smokes, rust free - $650 Leer Canopy - fits 93+ Ranger/Mazda Trucks $350 Bedliner with "Mazda" for 93+ Ranger/Mazda Trucks $100 Brand new Goodyear 235/75/15 Silent Armor tires $400 Free shit - GIRLFRIEND!!!!!!! Any info or pics needed, PM me please!
#505698 - October 20th 2011 7:58 am
[Re: wbud]
Loc: Russia
And what you think about this Holley carb? http://holley.com/0-80457S.aspSo the problem is that I can't understand is 600cfm fit for GM Goodwrench? Goodwrench engine is stock engine or customized? The second question - about new intake. Is intake for Rochester fit for 4barrel Holley? Thanks for support!
#505714 - October 20th 2011 8:23 am
[Re: wbud]
Loc: Bristol, TN
The GM Goodwrench label likely means the original engine was replaced with a new engine purchased at a dealership rather than rebuilding the original engine.
Most all aftermarket intakes will use a square base carb. They are easily seen for obvious reasons, it is a square shape where the carb bolts to the intake. Intakes that accept Rochester carbs have a larger opening at the rear and smaller openings at the front. The Edelbrock Performer and a few other aftermarket intakes will accept a Holley square flange carb or a Rochester style carb. If the intake you choose has only a square base, it will only accept a Holley type carb but there are adapter plates which can be bolted to the intake which will allow it to accept a Rochester.
There is one exception, there used to be a Holley Spreadbore carb which would bolt directly to a Rochester style intake, I am not sure if they still make this style or not. If you are buying new, I doubt you will have any issues.
Make sure you get the linkage parts you need to properly hook your transmission cable back up to the carb or you could damage the transmission.
'85 GMC Shorty '99 AWD Astro '55 Chevy 150 ex-racer "I thought you weren't allowed to talk to guys with vans??"
2 registered (Rudy, Wizard78),
5
46
25980 Topics
