New from SoCal
09:37 PM
by GoPilot
09:33 PM
08:53 PM
08:42 PM
05:29 PM
04:37 PM
02:37 PM
10:39 AM
Page 3 of 3 < 1 2 3
#562244 - May 14th 2012 8:19 am Re: 96 2500 [Re: Reed]
I think "NOt" jackin in up is BS rofl
I just pulled my 727 for B200 and theirs no way it would a slide out from under with out raise in van! 235-15's ,from ground up 2 bottom of rocker cant B more than 14" rolleyes
#562269 - May 14th 2012 11:22 am Re: 96 2500 [Re: DrBob]
DrBob Offline
Question on install
when I put the rear end from the 96 into the 90 I had to change yokes on the Rear End because the driveshaft out of the 96 was to short. Everybody said it was because the transmission in the 96 had a longer tail-shaft. I put the transmission in the 90 and used the 90 drive shaft.The 96 was still to short. Book says wheel base is the same.
#562292 - May 14th 2012 12:08 pm Re: 96 2500 [Re: heavy389]
Awbartley Offline
Loc: Myrtle Beach, SC
Originally Posted By: heavy389
I think jackin up more than 14" is BS rofl
I just pulled my 727 out from under and theirs no way it would slide with out bottomrolleyes
haha rofl worms Sorry Heavy had to do it....
** Southeast Van Council **
- '03 Chevy Astro AWD
- '84 Dodge Prospector
NEEDS: Side gullwing...
#562300 - May 14th 2012 12:19 pm Re: 96 2500 [Re: DrBob]
Originally Posted By: DrBob
Question on install
There would absolutely be a difference in driveshaft length depending of wheelbase. 127" vs. 109" That's an 18" difference. How the heck can that book say there isn't a difference?
The OD transmission did have a longer tailshaft, but I think the non-OD transmissions (even the newer ones like your 96) have the same length tailshaft as the older models.
The necessity for for a yoke change was probably because of a differnce in the size of u-joints, not driveshaft length.
#562416 - May 14th 2012 6:08 pm Re: 96 2500 [Re: DrBob]
DrBob Offline
I had to change yoke on the 96rear end because of length The 96 drive shaft was shorter and there both 109.6 in wheel base.
#562525 - May 15th 2012 7:51 am Re: 96 2500 [Re: DrBob]
Ah so. I guess there is a difference in the tailshafts then. Interesting.
Page 3 of 3 < 1 2 3
1 registered (al55), 8 Guests and 79 Spiders online.
Uncle_Fester 314
Wizard78 313
HighwayStar 250
frscke1 202
Lee7673 144
al55 125
newkirkinc1 123
Ripper 121
keystonekid1978 114
6621 Registered Users
25981 Topics
