#561418 - May 10th 2012 4:25 pm
Re: 96 2500
[Re: DrBob]
Good deal! 32RH is basically an A904 (no overdrive).
#561419 - May 10th 2012 4:27 pm
Re: 96 2500
[Re: DrBob]
The only thing extra I have to do is change the yoke on the Rear end. The 32RH has a longer tail shaft so I have to use the shorter drive shaft which has bigger U joints.
Edited by DrBob (May 10th 2012 4:29 pm)
#561916 - May 12th 2012 5:00 pm
Re: 96 2500
[Re: DrBob]
L lied didn't have to change drive shaft. Transmission is in. All's I got to do is get transmission fluid. That expensive shit.
#561946 - May 12th 2012 8:44 pm
Re: 96 2500
[Re: DrBob]
U think it is expensive look at the cost of the synthetic tyranny fluid lol
#561957 - May 12th 2012 9:18 pm
Re: 96 2500
[Re: Alikazam]
U think it is expensive look at the cost of the synthetic tyranny fluid lol I'm paying $7.11 a quart, That's high enough.
#562016 - May 13th 2012 3:43 am
Re: 96 2500
[Re: Reed]
You need at least 2.5 feet of clearance between the ground and the bottom of the rocker to drag a 904 or 727 transmission out from under a B-van. That's total BS! At 28.9" diameter, I'm not sure if my present tires (235/75 15's) are any taller or shorter than the stock H-70-15's, but I pulled my 727 with the van parked on a flat concrete driveway and slid it out right under the passenger-side rocker and never lifted any part of the body during removal or installation.
#562112 - May 13th 2012 11:26 am
Re: 96 2500
[Re: DrBob]
ATF +4 is expensive, but it's what's required. It is synthetic by the way.
#562121 - May 13th 2012 12:19 pm
Re: 96 2500
[Re: vandude360]
You need at least 2.5 feet of clearance between the ground and the bottom of the rocker to drag a 904 or 727 transmission out from under a B-van. That's total BS! At 28.9" diameter, I'm not sure if my present tires (235/75 15's) are any taller or shorter than the stock H-70-15's, but I pulled my 727 with the van parked on a flat concrete driveway and slid it out right under the passenger-side rocker and never lifted any part of the body during removal or installation. Really? I assume you didn't have it strapped to a transmission jack or anything. All I can tell you is that every time I have swapped a transmission in a van, I have had to jack up at least the passenger side to get clearance to get the transmission out. Granted, the last few have all been slant six transmissions so the bellhousing is a different shape, so maybe that is the difference. Guess I was wrong then.
#562125 - May 13th 2012 12:32 pm
Re: 96 2500
[Re: vandude360]
Loc: Myrtle Beach, SC
You need at least 2.5 feet of clearance between the ground and the bottom of the rocker to drag a 904 or 727 transmission out from under a B-van. That's total BS! At 28.9" diameter, I'm not sure if my present tires (235/75 15's) are any taller or shorter than the stock H-70-15's, but I pulled my 727 with the van parked on a flat concrete driveway and slid it out right under the passenger-side rocker and never lifted any part of the body during removal or installation. I dont think you should just call it out as BS....Reed was trying to help and there is no need for that. We all do things a little different, and if YOU can get a tranny out without lifting the van, then so be it....I pulled mine out and had to lift it way up....727 trans...we all do it different. But to call someone out as BSing is rude.
** Southeast Van Council ** " The person who says it can not be done, must not interrupt the person who is doing it." ~ Chinese Proverb. - '03 Chevy Astro AWD - '84 Dodge Prospector NEEDS: Side gullwing...
#562145 - May 13th 2012 3:50 pm
Re: 96 2500
[Re: DrBob]
Thanks for having my back, but I would rather be called on giving bad information than have people rely on the bad information I gave and have a problem. I don't think VanDude was trying to be rude, I have met him in person several times and he is a nice guy. I think his statement that my claim was BS was just a way of saying he disagrees with me, which is fine.
Like you say, there are lots of ways to pull a tranny. The way i do it might require more clearance than the way someone else does it. Plus, there are enough diferences in even B series dodge vans to make diferent removal methods necesary. Tire size, suspension rating, type of transmission, whether or not the side doors are barn or slider, etc... all will effect ground clearance and what is necessary to pull the transmission.
6623 Members
25993 Topics
