by NateNCBV
0 seconds ago
Early Junkyard Find
by NateNCBV
1 minute 31 seconds ago
my BRUBAKER BOX
by NateNCBV
3 minutes 20 seconds ago
Ready for carpet
by NateNCBV
4 minutes 24 seconds ago
by NateNCBV
5 minutes 22 seconds ago
"YOUR" Vans thru the years!
by NateNCBV
7 minutes 23 seconds ago
THE LONG BOYS CLUB
by NateNCBV
10 minutes 33 seconds ago
From the begining
by NateNCBV
18 minutes 2 seconds ago
by NateNCBV
20 minutes 3 seconds ago
just like to say thanks
by NateNCBV
22 minutes 13 seconds ago
#563422 - May 19th 2012 10:40 pm new guy looking for help with trans fluid cooler lines
cardinal Offline
Loc: Canada
Hello
I just joined (although I've been visiting the site for awhile).
I recently purchased a 1990 GMC Rally 2500, 5.7 (350) v8.
I'm pretty sure one (the lower one) of the transmission fluid cooler lines is leaking (ruptured). I have found puddles and followed drips down the driveway.
I've been trying to look up parts at auto parts shops and not even finding these lines listed..
My questions are - 1) is this an 'easy' fix? (I have replaced a power steering hose / line before, but I'm not very mechanically inclined - nor do I have a lot of free time at the moment.
2) Are these parts still available at auto parts shops? - am I calling them the right names?
I have to work tomorrow, so I will attempt to take and post some pics after I come back (I'll also introduce myself properly then..).
Thank you for taking the time to read.
c
#563450 - May 20th 2012 2:33 am Re: new guy looking for help with trans fluid cooler lines [Re: cardinal]
Rockauto.com
they usually have everything you need...
Oh & welcome to the site....
Edited by frscke1 (May 20th 2012 2:34 am)
#563492 - May 20th 2012 10:26 am Re: new guy looking for help with trans fluid cooler lines [Re: cardinal]
NateNCBV Online   content
You may end up having to bend up your own. It's just 5/16 or 3/8 steel tubing.
Have you tried a GM dealer?
#563505 - May 20th 2012 11:38 am Re: new guy looking for help with trans fluid cooler lines [Re: NateNCBV]
yeah When I replaced the trans lines on my van (88) there were no direct bolt on lines to be found. I had to get straight lines and bend them myself. Not hard to do with a little hand held pipe bender. You can use the old line as a pattern to bend the new one.
#563556 - May 20th 2012 8:26 pm Re: new guy looking for help with trans fluid cooler lines [Re: Galaxy]
cardinal Offline
Loc: Canada
Thank you for the replies.
So today I was talking with a respectable guy (backyard mechanic) and his opinion was that I could cut the lines and use fuel line and clamps..
I can't really do anything until Tuesday in any case as Monday is a holiday here... and I need to buy transmission fluid.
My transmission has MD8 written on it.
c
#563558 - May 20th 2012 8:43 pm Re: new guy looking for help with trans fluid cooler lines [Re: cardinal]
DrBob Offline
If you use any rubber lines make sure there made for Tranny fluid.
#563628 - May 21st 2012 2:59 am Re: new guy looking for help with trans fluid cooler lines [Re: cardinal]
SaabGuy Offline
yeah And keep the rubber line away from anything sharp. I mean anything. Better off with metal line.
#563659 - May 21st 2012 9:17 am Re: new guy looking for help with trans fluid cooler lines [Re: cardinal]
Well...if you go that route, you still need to at least single flare the steel tube where you cut them to keep the rubber hose from sliding off. Even clamped the hose can still slide off.
#563670 - May 21st 2012 9:50 am Re: new guy looking for help with trans fluid cooler lines [Re: cardinal]
invest/rent the proper tools to fix these lines correctly.
your trans fluid is the life blood of your transmission.
IF you blow off one of the rubber lines you can burn up the trans by running it dry.This can happen pretty quick.
#563674 - May 21st 2012 10:18 am Re: new guy looking for help with trans fluid cooler lines [Re: wookee]
DrBob Offline
I had a rubber line blow on the Interstate. Cost me my tranny. That's Y I say use lines rated for Tranny fluid.
1 registered (NateNCBV), 8 Guests and 96 Spiders online.
Rockinrednek, Margaret, ShortChevy, lilsparklez, Nerolus
6693 Registered Users
Wizard78 364
frscke1 324
HighwayStar 322
Uncle_Fester 250
NateNCBV 208
lukester 198
Lee7673 181
26226 Topics
