#567452 - June 08th 2012 10:19 pm
Re: Wetness on Bottom of Rearest Doors
[Re: CPSChevyVan]
there is a latch on the bottom and top
#567481 - June 09th 2012 11:28 am
[Re: RamVan2500]
Because the hi-top basically mounts flush in the rain gutters, water is no longer routed away from the doors via the gutter. It just flows up and over and right into the doors.
The cargo door gaskets on my 94 are in great shape, but after a hard rain the carpet is wet in the back corners.
#567503 - June 09th 2012 1:47 pm
[Re: RamVan2500]
Loc: Haddonfield, NJ
i use to have a similar problem. the gaskets for the rear break and side marker light housings were letting water through. took them out and sealed them up with black gasket maker. no more water. i made access panels to replace the bulbs from inside.
#567551 - June 09th 2012 6:38 pm
[Re: NateNCBV]
hmm good point... well it rained a little today and so far everything is dry as a bone. hope it stays this way!
#567552 - June 09th 2012 6:39 pm
[Re: pockets]
well vans starting in 1994 (as far as i know) have the markers light mounted external to the body, there are vents behind the unit but water doesn't flow up
#567603 - June 10th 2012 7:27 am
[Re: RamVan2500]
Loc: Scott County VA
I have the same problem. The volume of water off the high top in INCREDIBLE, even in light rain. The gutters on the G20 empty at the corners and they gush when its raining heavy.
If your gonna do it, do it in a Big Green Van!
#567605 - June 10th 2012 7:41 am
[Re: RamVan2500]
I never thought about High Tops doing that
#567613 - June 10th 2012 8:56 am
[Re: RamVan2500]
well vans starting in 1994 (as far as i know) have the markers light mounted external to the body, there are vents behind the unit but water doesn't flow up Also..unlike 93-back models, if you take the lenses out there is a steel panel behind them. No way for water to get to the interior that I can see.
#567651 - June 10th 2012 1:21 pm
[Re: RamVan2500]
Well I think I fixed it, I cleaned the gaskets as they were sticking to the door panels thus blocking the drainage holes on the bottom of the door.
26232 Topics
