#567896 - June 11th 2012 4:32 pm
power lock ?
Loc: sacramento,ca
on my 03 dodge ram van, the side doors the lock in only workiong sometimes when i unlock with power contrrol up front. other time it doesntmove at all. all other doors are working;thanks.
#567902 - June 11th 2012 4:57 pm
Re: power lock ?
[Re: 65dreamin]
It could be the actuator inside the door or the contact points are dirty. The contact points are on the door frame and door itself. When you open the door, you'll see them.
#567962 - June 11th 2012 9:01 pm
Re: power lock ?
[Re: 65dreamin]
Loc: sacramento,ca
thanks nate.just clean contact points off? what do i do if its actuator?thanks.
#568064 - June 12th 2012 12:16 pm
Re: power lock ?
[Re: 65dreamin]
If it's the actuator? Replace it I suppose.
#568142 - June 12th 2012 8:57 pm
Re: power lock ?
[Re: 65dreamin]
Loc: sacramento,ca
whts best to clean contact points off with?put anything on them after clean?thanks
#568145 - June 12th 2012 9:01 pm
Re: power lock ?
[Re: 65dreamin]
I always use crocus Paper. {brown paper bag}
#568148 - June 12th 2012 9:23 pm
Re: power lock ?
[Re: 65dreamin]
Loc: Myrtle Beach, SC
maybe some 1000 grit?
** Southeast Van Council ** " The person who says it can not be done, must not interrupt the person who is doing it." ~ Chinese Proverb. - '03 Chevy Astro AWD - '84 Dodge Prospector NEEDS: Side gullwing...
26244 Topics
