rear seat belt
by pearly
01:03 PM
What can you tell me about the 70's GMC Rally Van?
12:56 PM
12:47 PM
Cerberus, Shenandoah Valley Vans
12:46 PM
12:46 PM
vent visor or rain gaurd
12:46 PM
12:26 PM
Page 3 of 3 < 1 2 3
#578230 - August 09th 2012 3:15 am Re: odometer not working, 90 Ram Van 250 [Re: draggnastro]
RavshngOne Offline
Loc: Southern New Jersey
Wait - Draggnastro you mean to tell me you swapped out the entire cluster and ended up with a second bad speedo, this time - it only reads to 30 mph and the odo still doesn't work? The odds of that happening are very rare.
Did you:
* Look at any corrosion on the circular pin connector harness going to the back of the cluster that is responsible for the VSS?
* Open up the cluster and look at the three pin locations that the speedo snaps into the back of the cluster and look for any sign of bad connections?
* Put an ohm meter on the pin connection at the harness and the vss to check for a short?
* Really really really sure the VSS is working correctly?
The reason I question this is certainly to help - but the fact that the replacement speedo only reads to 30 mph seems to indicate a signal issue of some sort. If the speedo has failed could it produce the same result? I guess, but seems very unlikely to me.
Strange. I have a spare 90-92 speedo but the odo doesn't work on mine either.
#578231 - August 09th 2012 3:26 am Re: odometer not working, 90 Ram Van 250 [Re: draggnastro]
RavshngOne Offline
....and mine failed because of a circuit board issue so the gears should be intact. In the case you find your replacement has stripped gears as well, you're welcome to have mine smile
Edited by RavshngOne (August 09th 2012 3:27 am)
#578586 - August 11th 2012 6:06 pm Re: odometer not working, 90 Ram Van 250 [Re: draggnastro]
gears were stripped on the 2nd one too. Put my speedo back in and the speedo works fine now, the small gear inside the odo is whats bad. Ravishngone, pm sent
#578587 - August 11th 2012 6:10 pm Re: odometer not working, 90 Ram Van 250 [Re: RavshngOne]
Did you:
speedo always worked fine. The small gears that feed the odo strip very easily apparently.
Page 3 of 3 < 1 2 3
2 registered (jeffnjen, Star Dreamer), 7 Guests and 87 Spiders online.
6696 Registered Users
Wizard78 384
frscke1 343
Uncle_Fester 242
keystonekid1978 183
newkirkinc1 153
26247 Topics
