0 seconds ago
48 minutes 50 seconds ago
Tips on posting pics and links
by OldReadingGus62
50 minutes 30 seconds ago
Dissatisfied Customer
by Doc 2% of Canada, EH!!!!
Today at 07:26 AM
Today at 06:56 AM
Hello from the UK
Today at 06:47 AM
Rear breaks on a 2001 E350
by Garfield
Today at 04:48 AM
by Matman
Today at 02:51 AM
by Matman
Today at 02:40 AM
Hello from Utah
by TunaBoat
Today at 01:10 AM
Page 2 of 3 < 1 2 3 >
#578699 - August 12th 2012 6:55 pm Re: Fan quit working today [Re: JDouglas]
The blower motor is one the passenger side of the van behind the rad over flow bottle.......
.....Wookee
#579652 - August 18th 2012 7:15 pm Re: Fan quit working today [Re: JDouglas]
Pull the plug and put 12 volts to it and see if it runs , Check fuses ....Nothing else either bad motor or fuse or ground.hould be simple fix , have a cold ...one...smile
#582553 - September 06th 2012 3:52 pm Re: Fan quit working today [Re: JDouglas]
JDouglas Offline
Loc: North Carolina
Installed new blower motor today. Also replaced some rotted vacuum lines, PCV valve and the air filter (had to remove the doghouse)
But when I started the van, air comes out of everything but the front vents now. Bummer! What did I do, or didn't do?
1993 Chevy Van 5.0L 150,000 miles
"You are now, or soon will be, what your friends are"
#582632 - September 06th 2012 10:05 pm Re: Fan quit working today [Re: JDouglas]
JDouglas Offline
Loc: North Carolina
I discovered that the vacuum line had to recharge itself with air! Once that happened, air began coming out the front vents. All is well.
#582635 - September 06th 2012 10:20 pm Re: Fan quit working today [Re: JDouglas]
Happy Birthday Uncle_Fester Offline
Sweet!
#583881 - September 14th 2012 10:50 pm Re: Fan quit working today [Re: JDouglas]
JDouglas Offline
Loc: North Carolina
Removing the Engine Cover (doghouse) is a monster of a job! I changed the air filter, PCV valve and about 18inches of vacuum hose.
Here is where the blower motor comes out and the new one goes in.
#583890 - September 15th 2012 2:38 am Re: Fan quit working today [Re: JDouglas]
SaabGuy Offline
Yes. The doghouse can be a pain but look at it this way: You can do a lot of work while its raining and not see a drop of it.
#607329 - March 22nd 2013 8:56 am Re: Fan quit working today [Re: Uncle_Fester]
FreightTrain Offline
Loc: Denver, CO
Did you get this issue resolved? I have an 82 B150 with the same problem... intermittently. I discovered that it affects both a/c and heat this winter....
#607353 - March 22nd 2013 11:57 am Re: Fan quit working today [Re: JDouglas]
Ripper Offline
Loc: Queens, NYC
Nevermind. I didn't see some of the later replies when I replied......
The ground is a plug on one of the mounting bolts. They can get corroded, which would cause your exact issue. Slamming the hood made the connection shed a bit of corrosion. Unplug the wire and clean it and the lug on the mounting bolt. Use a little WD-40 and a stiff tooth brush. Plug it back in and see if that's the fix. Don't waste your time pulling the dash switch.
Edited by Ripper (March 22nd 2013 11:58 am)
Edit Reason: I'm a dumbass
Ripper
Queens, NYC
347-447-1672
#607361 - March 22nd 2013 12:15 pm Re: Fan quit working today [Re: FreightTrain]
Welcome to the site FreightTrain
3 registered (tide, pirate, Malle), 3 Guests and 70 Spiders online.
Uncle_Fester 300
Wizard78 300
Lee7673 131
al55 121
newkirkinc1 112
Mikemod63, cammyjee, sandalscout, jonnyray, JnyQst
6611 Registered Users
6611 Members
25974 Topics
